Power lose
When it reaches about 3000rpm if I put my foot down to go faster then the gear's start changing back down ànd I go slow down
Could it be something to do with multitronic software needs update
Id recommend a diagnostic check to see if any fault codes flag up. When was the gearbox oil.last changed as this can affect the gearbox changing gears.
Yea you could try a software update on the gearbox or needing a new sensor. Worst case scenario it's the module that may have failed.
Thanks guys will do
