Rear washers
My rear washer has stopped working any id
Hi there is a little plastic nozzle attached to the spindle under the black plastic cover for the spindle and wiper arm, the water comes through the middle of the spindle and the washer nozzle just pushes on, pull it off and give it a soak in warm water then blow through it, alternatively buy a new one they are only about a fiver, but first get someone to try the rear wash just to make sure the water is coming out of the spindle.
Thanks not that. turned out to be pipe in tail gate on motor
