Shaun8p Posted March 5, 2023 Share Posted March 5, 2023 (edited) Hello I have problems with my rear right door the window won’t work unless I take everything apart then put it back together then it works. But then if I take the keys out of ignition and try again I’m back to square one with it not working again. I have checked the harness in my drivers door which were frayed so repaired nothing seems to fix it. Plugged the car into my Carista and I’m getting a code for rear door module so changed the window motor and having same problems Any help would be appreciated thanks Edited March 5, 2023 by Shaun8p Spelling mistakes Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted March 5, 2023 Share Posted March 5, 2023 2 hours ago, Shaun8p said: Hello I have problems with my rear right door the window won’t work unless I take everything apart then put it back together then it works. But then if I take the keys out of ignition and try again I’m back to square one with it not working again. I have checked the harness in my drivers door which were frayed so repaired nothing seems to fix it. Plugged the car into my Carista and I’m getting a code for rear door module so changed the window motor and having same problems Any help would be appreciated thanks Hi can you publish the code please, this is where VCDS or OBD Eleven score as they give the part number of the offending module, also have you tried a global reset on all windows with the key fob. Steve. Quote Link to comment Share on other sites More sharing options...
