2005 B7 - Remote Key Fob Wont Program
Hi all
I have recently picked up an A4 2005, previous owner changed battery in the key and since then remote buttons on the key havent worked. Sure enough, ive tried to program the key the manual ways (In the ignition, turn on, hold buttons) to no avail. Red light blinks on the key.
I have VCDS and upon going into program the keyfob that way, VCDS will not allow me to use the drop down at the top - select Remote Key Fob Adaption.
No photo description available.
Key works in the doors and starts the car fine.
Faulty CCM?
Any advice greatly appreciated!
Thanks!
37 minutes ago, Steve Q said:
Have you done the key fob reset?
Cant says I have
Is that where you select Channel 0 and hit read/save?
2 hours ago, cpjvej2016 said:
Cant says I have
The video should advise how.
If that doesn't work then it could be an issue with the CCM, signal receiver.
Which video - the above 1 is 7 seconds long and is a Pizza ad.
lol
OK something is going on.
After I have clicked Save - its not saving the keyfob - the value goes back to 0.
My Keyfob is not recognised at all but I did find one ion the car that is not from this car (off another Audi) which does say recognised - so my plan was to keep that with the working key and just sue it as a keyfob but Alas, VCDS does not seem to be storing the fob :(.
Edited by cpjvej2016
Update - the 'other' key has randomly started working! Bonus.
  • 1 year later...
it is standart problem with keys 2004-2006 year with key number 8E0837220K . You should to make new key with remote 8E0837220Q (2007-2008 years). About this problem you can read here https://ikey.by/izgotovlenie-chip-klyuchey/audi-izgotovlenie-chip-klyuchey/izgotovlenie-chip-klyucha-audi-a4/, you should programm only new original key with number 8E0837220Q.
Edited by zakaz
