Interior Lights (Rear Driver's Side not working) - 2018 A5
Hi All,
I have recently purchased a 2018 Audi A5 2 door S Line Coupe, and the rear driver's side interior light (the strip just below the window, above the arm rest) isn't working. All other interior lights are fine, including the same one on the passenger side.
I've searched all over, but can't find much info about what it could be. Has anyone come across the issue before and is it something as simple as just changing the LED strip? If so, is there any guidance anywhere on how to do this?
Thanks in advance!
  • 1 year later...
On 3/21/2023 at 5:05 PM, Spenno said:
Hi All,
Thanks in advance!
Hi, i know it is a long time since you posted the problem, i have the same issue but the lights for the whole door don t work and i don t know what to do. Did you managed to fix it ?
