Lock does not function
SeanBRE
Go to solution Solved by coupe4,
Hi, I can put key blade in drivers door lock, turn it left or right, nothing happens? Fob works ok. I think this is a mechanical problem, anyone had this issue and been successful in finding a solution?
Thanks.
  • Solution
hi sean,id say at some stage the bar going from the door lock down to the lock mechanism was disconnected for some reason,greg.
Hi Greg, thanks for the info, do you know if this is easily fixed? Or if you do not,  do you know someone who does?
                Thanks alot
its straight forward enough,if you take off the door card and use a torch youi see the mechanism and hopefully the bar is there,it probably just needs to be slotted back into the barrel or back into the mechanism,it should be in one or the other,theres probably youtube videos,
