I have a very strange problem. I have Audi A3, 1.4 tfsi manual, 2011, engine stalls on a cold start. Nothing on the dashboard seems to be an electrical problem. Vcds scan shows no fault codes. Anyone got the same problem? Any solution?
Could it be an issue with the maf, crank sensor, lambda sensor or cam sensor?聽
I appreciate in theory a code should flag up.聽
Indeed though no 馃槙 fault codes 馃様 mate ...
On 7/15/2023 at 9:19 PM, VASSZACHARIS said:
I have a very strange problem. I have Audi A3, 1.4 tfsi manual, 2011, engine stalls on a cold start.聽
You imply that there is no stall on a hot start. Is that correct?
Indeed only on cold start when you switch on the car, after a while car stalls on the red light. It switch on again and works without problem. I am not quite sure if temperature is crucial. It appears to be on summer time as there is very hot here in Greece. This is an empirical notice.聽
So the problem is dependant on temperature, which may give a clue to somebody familiar with that engine. Unfortunately I am not and don't know what to suggest.
