Gen 1 R-Tronic Gearbox (Yellow) Dash Warning
GLYN S
After a bit of a drive in Auto Mode,I often get a dash warning stating "Gearbox Malfunction---OK To Keep Driving" and the Gearbox immediately reverts to Manual Mode.
I then continue my journey with no obvious problems in Manual.(2008 4.2 R8 with 26,000mls)
Has anybody had a similar experience ?. Any ideas of cause/reason ?.Any ideas for sorting the problem.Any idea where the port for fault-reading can be found ?.
I am very much "lost". ANY HELP WOULD BE MUCH APPRECIATED.
I'd recommend a diagnostic check to see if any fault codes flag up? Think the obd port is under the driver side lower dash. It could be a gearbox module issue.
What's the service history on the gearbox?
As degrading oil can affect the gear changes.
  • 4 weeks later...
5 hours ago, GLYN S said:
Hi Steve,many thanks for suggestions.
Can you recommend or know of any good Audi/diagnostic specialists in Leicestershire ?.
You're welcome. The only Audi independent specialist in Leicestershire is Chapman's based in wigston. Not that I've ever used them.
