Shark Plug Change Help
Hi All, just wondering is anyone can assist with this at all?
I have the 2017 1.4 TFSI and need to change my spark plugs.
However the engine is mounted differently to the 2.0l version and other 1.4 tfsi in other models, so it has couple of pipes across it preventing me getting to the back two coil packs. Have found loads of videos on how to change them but not for this configuration annoyingly.
Is anyone able to advise what these are and if I'm okay to remove for access?
The thicker black pipe at the back looks to be the air system, with electrical connectors I can pop off, but the smaller silver pipes and the smaller black plastic part that the silver pipe goes into worry be as unsure what they are,
Any help would be greatly appreciated
@Jezza92 Did you have any luck with this? I'm stuck too!
