3.0tdi turns over won’t start… progress maybe 🤷🏼‍♂️
So here is the story so far…
I had an auto electrician come and have a look at the car and he said that the ECU was knackered and that he was almost positive as soon as I got my ECU cloned the car would start up… now I’ve had my ECU cloned and fitted the new ECU and now it’s throwing the faults up as below. Now the ones which I think are causing the problem is the P1040 & P1042 but the problem is I aren’t getting a voltage to the plugs on the injectors. Now I can’t find a lot on line about this but what I can find is everyone pointing to the ECU… but my ECU can’t be the issue as I’ve just had it cloned 🤦🏼‍♂️. Anyone shed any light on it or help in any way?
[Friday,29,September,2023,10:21:18:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 21.3.0.0
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WAUZZZ4L27D033457   License Plate: FRIDAY 2ND TEST
Mileage: 179410km-111480mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 3742 46 47 4F 52
          55 56 61 62 6D 6F 72 76
VIN: WAUZZZ4L27D033457   Mileage: 179410km-111480miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4L0 910 401 K    HW: 4L0 907 401
   Component: 3.0L V6TDI  G001AG  0030
   Revision: --H03---    Serial number:
   Coding: 0011775
   Shop #: WSC 31414 790 00001
   VCID: 2A5BB7AF85FF20DBBD-807E
8 Faults Found:
004160 - Supply Voltage A for Injectors
               P1040 - 005 - Circuit Malfunction - MIL ON
             Freeze Frame:
                    Fault Status: 11110101
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2006.04.23
                    Time: 17:20:44
             Freeze Frame:
                    RPM: 84 /min
                    Torque: 616.2 Nm
                    Speed: 0.0 km/h
                    Inj. Quantity: 69.7 mg/str
                    Voltage: 0.23 V
                    Pressure: 269.8 bar
                    Temperature: 10.8°C
004162 - Supply Voltage B for Injectors
               P1042 - 005 - Circuit Malfunction - MIL ON
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2006.04.23
                    Time: 17:20:44
             Freeze Frame:
                    RPM: 84 /min
                    Torque: 616.2 Nm
                    Speed: 0.0 km/h
                    Voltage: 0.23 V
                    Pressure: 269.8 bar
                    Temperature: 10.8°C
009301 - Diesel Particle Filter; Differential Pressure Sensor
               P2455 - 001 - Short to Plus
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Temperature: 893.2°C
                    Temperature: 554.6°C
                    (no units): 0.0
                    Absolute Pres.: 81.6 mbar
009258 - Exhaust Gas Temperature Sensor; B1 S3
               P242A - 000 - Malfunction
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    (no units): 0.0
                    Temperature: 14.4°C
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 001 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2006.03.15
                    Time: 12:00:34
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Duty Cycle: 1.0 %
                    Voltage: 11.93 V
                    Duty Cycle: 15.0 %
                    Temperature: 13.5°C
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 001 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2006.03.15
                    Time: 12:00:34
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Duty Cycle: 1.0 %
                    Voltage: 11.93 V
                    Duty Cycle: 15.0 %
                    Temperature: 13.5°C
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 001 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2006.03.15
                    Time: 12:00:34
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Duty Cycle: 1.0 %
                    Voltage: 11.93 V
                    Duty Cycle: 15.0 %
                    Temperature: 13.5°C
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 001 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2006.03.15
                    Time: 12:00:34
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Duty Cycle: 1.0 %
                    Voltage: 11.93 V
                    Duty Cycle: 15.0 %
                    Temperature: 13.5°C
Readiness: 1 2 0 0 1
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 FK    HW: 09D 927 750 FK
   Component: AL 750 6A           0940
   Revision: 00H52000    Serial number:
   Coding: 0000504
   VCID: 7CF741F73FEB6E6B9F-8028
No fault code found.
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H21001
   Coding: 0038033
   VCID: 285F4DA79BF312CBAB-807C
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2023.09.29
                    Time: 10:16:18
             Freeze Frame:
                    Count: 0
                    Count: 4353
                    Count: 297
                    Count: 42496
Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601000473437
   Coding: 0000147
   Shop #: WSC 00579 210 89301
   VCID: 63C51A8BA255B193BE-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 729 S    HW: 4E0 035 729
   Component: Interfacebox    H43 2830
   Revision: 00000000    Serial number: 386GV067515281
   Coding: 0002002
   VCID: 3F8DF6FB6E7DB573FA-806A
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH02 0060
   Subsystem 2 - Serial number: 00000000460480
   Subsystem 3 - Serial number: 0103.07.060000000100010728ÿ
   Subsystem 4 - Serial number: 010728ÿ
Address 08: Auto HVAC        Labels: None
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0040
   Revision: 00---008    Serial number: 00000000051235
   Coding: 0001046
   VCID: 61C91083B849A383AC-8034
1 Fault Found:
01592 - Air Quality Sensor (G238)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2023.09.29
                    Time: 10:16:23
             Freeze Frame:
                    Temperature: 10.0°C
Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H17 0240
   Revision: 00000000    Serial number: 4F0907279
   Coding: 0011101
   VCID: 3169A0C3A82953037C-8064
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H08 0080
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
   Part No SW: 4L0 910 111 A    HW: 4L0 035 111
   Component: CD-Changer      H41 0100
   Revision: 00000000    Serial number: AUZ5ZBF3029137
   Shop #: WSC 00000 000 00000
   VCID: 1E336B7FC9B7DC7BD1-804A
Address 15: Airbags        Labels: 4L0-910-655.lbl
   Part No SW: 4L0 910 655 B    HW: 4L0 959 655
   Component: 31 AIRBAG AUDI8RH38 0120
   Revision: 05H38000    Serial number: 0037GD06DEJ5
   Coding: 0013105
   VCID: 2C57B1B78F0B3EEB4F-8078
   Subsystem 1 - Serial number: 6332QSME0F433F1DT
   Subsystem 2 - Serial number: 6342QSME0F3035215
   Subsystem 3 - Serial number: 6352QSME0F31146FM
   Subsystem 4 - Serial number: 6362QSME1241403D6
   Subsystem 5 - Serial number: 63734SME11632061L
   Subsystem 6 - Serial number: 63834SME116D2239$
Address 16: Steering wheel        Labels: 4F0-910-549.lbl
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90054061950102
   Coding: 0102142
   VCID: 66C3039F5167C4BB59-8032
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
   Component: KOMBIINSTR. M73 H17 0110
   Revision: 00300000    Serial number: 5HJ321M76
   Coding: 2593443
   Shop #: WSC 27313 067 57207
   VCID: 23455A8BE2D5F193FE-8076
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 C
   Component: Heizgeraet      H07 0060
   Revision: 0000000E    Serial number: 00000009011043
   Coding: 0000002
   VCID: 60CF1587B343AA8BA3-8034
4 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
            004 - No Signal/Communication - Intermittent
00456 - Control Module for Access and Start Control (J518)
02072 - Control Module for Energy Management (J644)
01408 - Under-Voltage Shut-Off (fixed Value)
            000 - - - Intermittent
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B06715804B
   Coding: F55BBE7F302202
   Shop #: WSC 80093 222 69422
   VCID: 6CD771B74F8BFEEB0F-8038
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2023.09.29
                    Time: 10:16:20
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 B    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7550
   Revision: --H03001    Serial number: 15.1528-0095.2
   Coding: 0015510
   VCID: 295948A380F92BC3B4-807C
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 D
   Component: MNS ECE         H48 0850
   Revision: 00000000    Serial number: 399GU067530216
   Shop #: WSC 00579 210 08335
   VCID: 3B7582EB7A65A953D6-806E
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00-00000
   Coding: 0002651
   VCID: 2F6DA6BBBE1D45F36A-807A
Address 46: Central Conv.        Labels:. 4L0-910-289.lbl
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01016234250000
   Coding: 7348475
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
2 Faults Found:
01504 - Bulb for License-Plate Light (X)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 63
                    Mileage: 177361 km
                    Time Indication: 0
                    Date: 2020.11.19
                    Time: 18:58:40
01696 - Footwell Lighting; Rear Left (W45)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 13
                    Reset counter: 63
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2006.03.15
                    Time: 12:02:20
Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
   Part No SW: 4L0 910 223 B    HW: 4L0 035 223
   Component: DSP-AU716       H20 0100
   Revision: 11S00001    Serial number: 01507060321569
   Coding: 0000003
Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000002416
   Coding: 0011101
   VCID: 5EB32B7F89379C7B91-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00-00000
   Coding: 0002651
Address 55: Headlight Range
Cannot be reached
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0570
   Revision: 00000000    Serial number: 388G%067539581
   Coding: 0000001
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000029587
   VCID: 64C71997A75BB6AB47-8030
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2607171435
   Coding: 344630393135313035442056413032363037313731343335
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 103
                    Mileage: 179414 km
                    Time Indication: 0
                    Date: 2023.09.29
                    Time: 10:16:18
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0050
   Coding: 0002058
Address 6D: Trunk Elect.        Labels: 4L0-910-945.clb
   Part No SW: 4L0 910 945     HW: 4L0 827 851 A
   Component: ValeoHeckdeckel H20 0280
   Revision: --H20001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 1 - Part No: 4L0 910 946
   Subsystem 2 - Serial number: E5030100B
   Subsystem 3 - Serial number: RD22.07.06--H20001001C0142ÿ
   Subsystem 4 - Serial number: 1C0142ÿ
1 Fault Found:
00317 - Rear Lid Control Module (J605)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 103
                    Mileage: 179414 km
                    Time Indication: 0
Address 6F: Centr. Conv. II        Labels:. 4L0-910-290.lbl
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 001845080-----
   Coding: 0000001
   VCID: 65C10493AC61CFA350-8030
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0050
   Coding: 0002058
Address 76: Park Assist        Labels: 4Fx-910-283.lbl
   Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
   Component: Parkhilfe 8-Kan H12 0060
   Revision: 00H12000    Serial number: 06320620100691
   Coding: 0201146
End-------------------------(Elapsed Time: 02:47)--------------------------]
hi mark,this happened to a pal of mine with a 2007 Q7,a uk company had done work on his ecu and when he got it back and fitted it he called them and they sorted all the faults while he was on the phone.this might be worth a try?greg
Thanks mate. I rang them yesterday but apparently they can’t help. Unfortunately I’m probably going to have to sell the car, I just can’t justify spending anymore on it.
