Central LED display
Hi Guys,
My A6 C5 allroad is up and running and l am really pleased with it. I have renewed the front wheel bearings which were very noisy and sent the instrument cluster away for repair which now works beautifully. My problem now is its all in Spanish and l would like to change the display to English but l may have a knob missing as l have no knob to access the menu which should be on the central console but it aint so does anybody know if it should be there (the knob) or is my model different and can be adjusted in another way.
Cheery Bye
Capt Dave
Dave,
If you have Vagcom you should be able to change the language to English. It does sound though that you need a knob to set it up manually as you suggest.
