Driving System Failure YELLOW WARNING
Hi guys I have had an issue with my Audi a3 8Y. Initially the eml light would come on was told this was due to evap caused no issues with the car. Eventually the car came up with a yellow driving system failure sign causing the car to misfire, idle. However , upon flicking the ignition it would be back to normal.
I have been told it was something to do with the charcoal canister on the EVAP but might be wrong. Can anyone give me any tips or ideas I’m struggling to have a fix on this.
EML LIGHT IS CURRENTLY ON
START/STOP not working also
No as the warranty has just finished. Also had a look online said something to do with the purge valve. Had the fault code P04110 come up.
Even though it's just out of warranty you should be able to have good will from Audi. From what I've researched it'll need replacing
Alternatively I'd recommend you take it to an Audi independent specialist
