Brake pad warning light comes on after ignition is on
My 2018 SQ5 low brake pad warning light and audible noise comes on after ignition is on, brake pads, discs and sensors changed but no help, no faults showing up when coder plugged in, any help/advice welcome.
Edited by the tizer 1
12 hours ago, Magnet said:
Front or backs replaced Ian?
Hi Gareth
The rear pads and discs replaced, the front has plenty of pads left on them, was told only two sensors fitted to this model O/S rear and N/S front, both sensors replaced
12 hours ago, Steve Q said:
Could be an issue with the wire in the brake pad which lets the sensor know when the pad is low. Or the sensor or sensor wiring
Hi Steve
both rear pads and discs replaced and O/S rear and N/S front sensors replaced, (was told that is the only sensors fitted to model) front brakes have plenty of pad left on them.
Hi,
It could be that the wire into the brake pad has become
dislodged, I had the same problem a while ago.
worth a look.
Brian.
