22 inch OEM alloy tyre recommendations?
Hi, I have just upgraded to 22’s and need a set a new tyres, please can you recommend some good quality tyres for these alloys? Thank you
I run 22" wheels and have 285/35 tyres fitted which I sourced on Oponeo.
Nice tread pattern and good grip to wear ratio.
I can't remember the make/model and it's dark out now but I think they are Nexen
Most online tyre suppliers have a budget, mid-range and stupidly expensive range.
I went mid-range and they were less than £200 each.
HTH.
Chris
Hello Iby,
I guess you have worked out/taken advice on the correct width and profile (very low) you will need to retain the correct rolling diameter of these large wheels - ?
