Fault codes help
My a6 occasionally goes into limp mode with flashing coil light. When car is stopped and left a few minutes it appears to reset and go back to normal. I have scanned and found 2 faults - p200200 and p23700. Advice appreciated pleaseIMG_4592.thumb.png.75a4fe7383b60ff8d25526ed71c8c23f.png
Hi P2002 is the low pressure EGR cooler have a look on the site archives this is well documented the cooler gets blocked with adblue crystals and fails its a horror to replace its not the parts so much as the labour charges, the other one is the MAP sensor which is cheap and easy to change.
