C7 3.0tdi fwd manual engine/gearbox codes
Hello all, I'm seeking advice on the 3.0tdi fwd manual out of curiosity and seems a rare car.
Does anyone know what the engine codes are for this version and gearbox codes/model of 6 speed manual?
Thank you for any advice or info on this model is greatly appreciated 🙂
Just trying to increase my knowledge base.
Solved by Steve Q
lots off work steve  lots
  • Solution
Just an update I got hold of further information regarding the engine and gearbox codes thanks to Luke Voss, a member of the A6 c7 UK club.
Further research:
Pun engine code was fitted to the 2.0tdi.
Gearbox fitted with 3.0tdi was the oa3 gearbox which has two other codes:
JHM kit (.56) uses 01E311362D and 01E311160D.
The JMG transmission part numbers 0A3311352B and 0A2311362F which yield a .53 ratio. These JMG gears are less than half the price of the .56 gears.
