Carista - Fuel prime on tdi
Go to solution Solved by DaveOL89,
Morning all,
my service parts arrived today (woo).
one thing I want to do is change the fuel filter (2.0l tdi 2014).
I have Carista and it shows that you can prime the fuel system on their website (see below)
however I鈥檝e seen a few posts floating around the internet saying it can only do it with the C6!聽
has anyone actually used this feature on Carista on a c7 tdi and can tell me if it worked?
I don鈥檛 want to strip the filter off and out the new one on only to find I can鈥檛 prime it with what I have. (I do have Carista premium).
Many Thanks,
Dave聽
1 hour ago, DaveOL89 said:
Morning all,
Many Thanks,
Dave聽
Hi if the filter is mounted under the floor [tube type] pour a little diesel in to it and once connected cycle the ignition on and off eight times for ten seconds a time and the lift pump should fill it, once started run for at least five minutes as the HPFP is self bleeding and chucks out any air through the return side.
  • Thanks 1
Hi Steve,
I had planned on that but saw on a post someone did that and this hpfp gave up the ghost with a hefty bill.
although I鈥檓 sure if the the filter is pre filled aswell it shouldn鈥檛 cause too much of an issue 馃
The HPFP relies on fuel to lubricate it, running it dry will cause damage. That's why pre-filling the filter and priming as much as possible with the lift pump before cranking the engine is necessary.
  • Thanks 1
This is why I was hoping someone could tell me from first hand experience if Carista can do this, I鈥檒l dog it out tomorrow and test run it and see聽
Hi most people have either VCDS or OBDeleven they both do it, Carista, no idea, if you consider I always did my filter change over 270k the way I described I can't see the problem, they do it that way at most garages thats where I learned and never had a problem.
  • Thanks 1
  • Solution
Just for some clarity and n this, Carista does indeed do fuel promo by, aswell as gearbox configuration for after changing the oil and pretty much anything else you could need聽
