Looking for replacement parts, audi a6 front caliper carrier
Hi,
I am looking for replacements for the bolts on the front caliper carrier. The carrier has a "bolt"with threaded hole. to be honest i have no idea how they called.
I snapped the bolt while replacing the disc, and I am stuck because I cannot find replacement anywhere. The only option I have found is to replace the entire carrier.
If anyone can point me in the right direction, I would appreciate it.
Edited by Vipersq
hi,
none of them offering those bolts. i think only way to deal with it is to buy whole carrier. I don't even know how those bolts are called/
Hello Chris,
Apologies if you know this, but this application critical bolt will have to be replaced with a genuine part, or as a minimum, a bolt of the same tensile strength.
Are you saying these are not available at the main dealer?
