A6 heating problems
Hi I've had an Audi A6 3 litre diesel for 3 years with various problems
Now I have no hot air on the driver's side but if I turn the heat down to cold on the passenger side then I have heat on the driver's side can anyone please help
Haven't had the heater matrix checked
Car temperature is fine had 2 diagnostics one said not sure the other one said matrix dash out and 1,000 but he couldn't guarantee it was the matrix
Audi want 165.00 for an hour but again can't guarantee it will be done in an hour may need further investigation
Does it maintain proper heat on the drivers side when you turn passenger side to cold?
Yes I said this on the post I put up is there a genuine Audi mechanic on this site or any one that has had the same problem or am I wasting my time on this Audi site
Ok. Best of luck.
If you want "genuine" Audi expertise without wasting your time please go to Audi and pay for it. On the other hand if you want free help from fellow Audi enthusiasts you are in the right place, but you might have to wait a while until somebody chooses to reply.
Cliff coggin go to bed
With his attitude that may be a very long wait.
Don't know if this helps mate we had no heating changed the heater matrix though no luck
turned out it was the coolant control valve sits under windscreen on passenger side under scruttle panel. Easy access and removal
Brand like febi cost 60/70 approx
Though we had no heat at all . So may not apply to your situation
Hope that helps
Edited by Rizwan Patel
Thanks for this
Hmm, similar issue here. Put the heating to auto get cold air, irrespective of temperature setting, engine is up to temp, coolant full.
Change to manual settings, hot air but only on the passenger side, passenger footwell, side vents, passenger centre and rear all toasty, drivers cold so closed them.
No fault codes. Suggestions that the system needs flushing? Or a stuck heater door but the one for the drivers side needs the foot pedals and column removing for access so that's not happening. Having to drive with a blanket FFS. Any ideas
