justinaj Posted Thursday at 10:33 PM Posted Thursday at 10:33 PM Jumps out of gear and "Gearbox Malfunction" appears on dash. Sometimes works for a little while before this happens. Scanned with VCDS and I am getting 20888 - Pressure Control Solenoid 1 - P0748 error. I have replaced the ATF, motor, filters and all the solenoids. Does anyone have any experience with these.. could the TCU be faulty or is there another hardware element within the ATU which could be at fault. -- VCDS OUTPUT -- Address 02: Auto Trans Labels: 0CJ-927-156.clb Control Module Part Number: 4G0 927 153 L HW: 0CK 927 156 Q Component and/or Version: 0CK 20TDI RdW H01 0002 Software Coding: 100001 Work Shop Code: WSC 02391 785 00200 ASAM Dataset: EV_TCMDL382021 002014 (AU57) ROD: EV_TCMDL382021_AU57.rod VCID: 323AC2AFE4A6AE7A99F-8066 1 Fault Found: 20888 - Pressure Control Solenoid 1 P0748 00 [10101111] - Electrical Malfunction MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 1 Fault Frequency: 8 Mileage: 332432 km Date: 2000.00.00 Time: 00:00:00 Engine RPM: 0 /min Driving position: d ATF temperature: 14 ∞C Transmission output speed: 0 /min Voltage terminal 30: 12.7 V Engine torque: 0 Nm selected gear: N Ctrl. mod.: operating condition: regular operation Auxiliary pump for transmission: requesting function: Fill hydraulic press. accum. Auxiliary hydraulic pump for transmission oil: current: 4 A Oil pressure reservoir: pressure: 0.7 bar Pressure of clutch 1: actual value: 0.0 bar Pressure of clutch 2: actual value: 0.0 bar Clutch status: New Unlearning counter according OBD: 40 Occurrence_counter_over_length_of_life: 206 -- Thanks!!
Steve Q Posted yesterday at 03:34 PM Posted yesterday at 03:34 PM Id definitely say it could be the megatronics unit. You could send this off to be tested.
justinaj Posted 4 hours ago Author Posted 4 hours ago Thanks for the response, know of any good businesses to send one off to? Thanks!
