Danko74 Posted Monday at 06:40 AM Posted Monday at 06:40 AM Hello, My Q4’s charging flap is locked and I’m unable to unlock it. This has happened once before, and at that time I was able to release it using the emergency cord. However, this time the emergency release doesn’t seem to be working—possibly because I pulled it too hard the last time. I've looked online and it appears this is a common issue with this model. f you have any suggestions or new advice, I’d really appreciate it. Thanks in advance for your help!
Magnet Posted Monday at 08:09 AM Posted Monday at 08:09 AM Your Town/Country location Lukas - really??
Danko74 Posted Monday at 08:18 AM Author Posted Monday at 08:18 AM Sorry...I believed it was the work location field...changed! Mod. note- previously Brothel.
Magnet Posted Monday at 08:49 AM Posted Monday at 08:49 AM We are a welcoming group here, so please don’t extract the urine Lukas.
Danko74 Posted Monday at 08:57 AM Author Posted Monday at 08:57 AM Alright, calm down...I'm not trying to make fun of anyone, but just to lighten the mood, as I'm trying to find a solution to my problem. 1
Danko74 Posted Tuesday at 10:37 AM Author Posted Tuesday at 10:37 AM Quick update: The car has been dropped off at the Audi garage to resolve this issue, the air-con button issue along with a free update to the braking system. They mentioned it’s a well-known issue reported by Audi HQ. Please check your car and contact your Audi garage asap!
Danko74 Posted Tuesday at 12:23 PM Author Posted Tuesday at 12:23 PM The note from the Audi garage: Inspection Notes: Confirmed customers complaint of charging flap issue, checked and found actuator to be defective causing issue to occur, will require high voltage charging flap unit with actuator F496 replacing and re-checking (£390 !!!!) F496?? This should be the right Part number: 8V0862159 I'm a bit confused I'This should be the Part number: 8V0862159This should be the Part number: 8V0862159This should be the Part number: 8V0862159
