Jim Ridley Posted June 7 Posted June 7 Hi to you all would any of you guys have a link to or a sequence for Coding a Tow Bar to 2019 Avant using VCDS Thanks in advance Jim
Jim Ridley Posted June 8 Author Posted June 8 almost got it sorted just cannot access 13 Auto Dist Reg in VCDS the controller is not responding followed these instructions all of it worked but cannot access STG 13 Coding applies to Audi A6 C8 STG 19 > Installation List > "69 - Trailer/Anhänger" - Activate STG 01 > Coding > Byte 5 > Bit 4 "Trailer installed" - Activate STG 09 > Coding > Byte 13 > Bit 4 "Hitch ECU,installed" Activate STG 13 > Coding > Byte 3 > Bit 3 Activate STG 17 > Coding > Byte 14 > Bit 5 "Trailer, YES" Activate STG 46 > Coding > Byte 14 > Bit 6 "Trailer control unit, 0=not installed / 1=installed" Activate STG 6D > Coding > Byte 01 > Bit 7 "Trailer Recognition installed" - Activate STG A5 > Coding > Byte 14 > Bit 1 "FW_AAG,installed" Activate 1
Solution Jim Ridley Posted June 9 Author Solution Posted June 9 Thank you mate ,after a bit more digging and a bit of a disagreement with a guy on VCDS it appears I dont have this module in the car so this I why I could not access it , STG 13 > Coding > Byte 3 > Bit 3 Activate refers too (auto distance regulation) =adaptive cruise control ,as I dont have this on the car I dont need this section so all sorted Cheers Jim 1
AlexR Posted 3 hours ago Posted 3 hours ago Had my dealer retrofit the stowable Audi Tow Bar. Works fine and has also added a ‘Tow Bar’ function to the MMI Reversing Camera that shows an orange line and dot where the tow bar is. i gather the software also modifies the Stability Control function to optimise handling with a caravan under tow. It also adds a caption showing if the tow bar is not safely locked. When towing a different set of green indicator lights shows on the instrument panel when indicating. Wish I had ordered this at build as the retrofit was costly. The parts were around £1200 plus a hefty chunk of labour.
