Fra25 Posted Friday at 01:19 AM Author Posted Friday at 01:19 AM Steering wheel symbol illuminated, ESP symbol illuminated. MOT man won’t test it, I had a garage connect their diagnostic equipment - “needs coding, not something we do unfortunately”. I bought it with a faulty OSF window/door - intermittent power, I replaced a broken window regulator and a corroded a-pillar harness socket. I reconnect the battery and the warning lights appear. Any advice whatsoever very much appreciated.
Steve Q Posted Friday at 06:22 AM Posted Friday at 06:22 AM This could be caused by the battery if it's old and not operating properly. Might be worth having it checked first. 1
daveyboy1967 Posted Friday at 10:54 PM Posted Friday at 10:54 PM I had a loose wheel speed sensor that was throwing up similar problems with warning lights, might be worth checking mate. 3
Steve Q Posted Saturday at 07:21 AM Posted Saturday at 07:21 AM 8 hours ago, daveyboy1967 said: I had a loose wheel speed sensor that was throwing up similar problems with warning lights, might be worth checking mate. That's a good point Dave.
Fra25 Posted Saturday at 09:55 AM Author Posted Saturday at 09:55 AM (edited) On 6/27/2025 at 7:22 AM, Steve Q said: This could be caused by the battery if it's old and not operating properly. Might be worth having it checked first. Thank you. Man at the garage says he’d tested the battery when he read codes, also looks relatively new. 11 hours ago, daveyboy1967 said: I had a loose wheel speed sensor that was throwing up similar problems with warning lights, might be worth checking mate. I should definitely check those next, thank you. Edited Saturday at 10:00 AM by Fra25
Steve Q Posted Saturday at 01:40 PM Posted Saturday at 01:40 PM 14 hours ago, daveyboy1967 said: I had a loose wheel speed sensor that was throwing up similar problems with warning lights, might be worth checking mate. atleast you can rule out the battery.
Fra25 Posted Monday at 08:32 PM Author Posted Monday at 08:32 PM I checked sensors, and got good readings on OBD11. I’ve seen forum posts from people with similar symptoms/codes - establishing basic settings for the Steering Angle Sensor is a common solution. Ive tried the whole standard calibration procedure (and a few variations) several times to no effect. The steering angle data is constant at 0 (live torque and rate data is good). Since my calibration attempts the steering is now much heavier, engine idle speed increased, and a new fault code 01309 Power Steering Control Module.
daveyboy1967 Posted Monday at 10:04 PM Posted Monday at 10:04 PM (edited) In my case the sensor was functioning perfectly and would give good readings, it just wasn't positioned correctly in relation to the wheel and so would throw up errors while the car was being driven. Edited Monday at 10:07 PM by daveyboy1967 Edited for clarity.
Fra25 Posted Monday at 11:03 PM Author Posted Monday at 11:03 PM 31 minutes ago, daveyboy1967 said: In my case the sensor was functioning perfectly and would give good readings, it just wasn't positioned correctly in relation to the wheel and so would throw up errors while the car was being driven. Thank you. I’ve exhausted patience with it, I don’t know a lot to do with cars and less with electronics. Will likely be gone for scrap. Appreciate your replies.
