Roof boot problem
Hi all I'm new here but need advice if possible, roof says in secure won't work off fob or button and boot wont open it's a 2008
You'll need a diagnostic check to see if any fault codes flag up.
It's probably the roof clamps that has failed. Problem if you can't get into the boot as you could manually control the boot from there.
