19Stacey85. Posted 16 hours ago Posted 16 hours ago (edited) Hi we have had the Ac compressor changed it's new Not a reconditioned unit and replaced the Ac switch.. The AC switch just turns it's self of straight away.. we now we have this weird noise since having the AC gased.. We don't hear it in the engine bay or on the outside of the car just inside the car.. I have attached some videos if anyone has experience same thing please help and share your experience. Thanks in advance PXL_20250628_224822568.mp4 PXL_20250628_171129043.mp4 Edited 15 hours ago by 19Stacey85. Added files
cliffcoggin Posted 5 hours ago Posted 5 hours ago I am getting only broken audio, not video, sounding like an engine revving. Nevertheless I suggest you take it back to whoever did the job for a diagnosis.
Sid2020 Posted 4 hours ago Posted 4 hours ago I cans access your files but The evaporator is the main ac component behind the dash and changes fluid into gas to generate the chilling effect and is usualy silent, I have came across noisy heater boxes when ac in engaged but nothing to load. Too much gas in the system can cause a grinding noise from the ac pump at higher revs but this would be very noticeable
