dave72 Posted 12 hours ago Posted 12 hours ago drivers foot well is damp just mainly the middle of the carpet sills is dry where bonnet pull is dry behind peddles is dry h put a watering can down scuttle panel drain water flew out of the bottom anyone got any ideas
dave72 Posted 3 hours ago Author Posted 3 hours ago think i have found out where my water ingress is coming from its washer fluid topped up 3 times today and dropped below the plastic strainer cup does the pipe run down the drivers side
cliffcoggin Posted 2 hours ago Posted 2 hours ago Colin. I have merged your two topics. It keeps things tidy.
Steve Q Posted 2 hours ago Posted 2 hours ago Keep us posted on how you get on. Let's hope it is what you think and not a heater matrix. Is it losing coolant?
dave72 Posted 1 hour ago Author Posted 1 hour ago 13 minutes ago, Steve Q said: Keep us posted on how you get on. Let's hope it is what you think and not a heater matrix. Is it losing coolant? Hi will do it’s dry around tunnel/centre counsel screen wash is going down without using it filled it 3 times today and every time it’s been below the plastic cup strainer
Steve Q Posted 1 hour ago Posted 1 hour ago 1 minute ago, dave72 said: Hi will do it’s dry around tunnel/centre counsel screen wash is going down without using it filled it 3 times today and every time it’s been below the plastic cup strainer Sounds like it's that then.
