Crank no start
Thanks
Checked compression tester and it works
Friend checked it on his car all readings for his car are consistent
It surprises me that you are getting zero on all cylinders , yet noticing the escape of air (compression) when disconnecting the tester.
If indeed there is zero on all cylinders, then a next move could be to check the valve timing in case the chain has jumped some teeth - but it’s all guess work!
I did a trick putting drops of oil in spark plug holes and reconnecting spark plugs and coils and I noticed compression being built like it was wanting to turn over on the second attempt of cranking same thing
I’ll have a look at what u mentioned appreciate it
