Sunroof Problem
Ive just picked up an 2006 A4,
The sunroof tilt works fine but doesn't open up. When I turn the dial to open it moves about a cm and the goes back. When I got it the metal clips on the side of the manual slide were popped up and stuck in the rubber so I sorted that. Could it be the pinch protection detecting something? Any ideas?
Yeah nothing on the sun roof, I’ve done a bit of looking up and have seen it can be sticky rails or debris in the rails. The electric seem to work fine it just seems to detect something and give up!
Have you scanned the car with VCDS? Audi sunroofs needs to go through a relearn process if the motor has been renewed for example.
