engine
hi guys,this is probably a long shot but im looking for an engine for my 1998 a4 2.8 [engine code ACK],i bought the car through the forum a few months ago and got it shipped here to ireland,it has low compression on bank 2 cylinders so a replacement engine is my plan,if anyone knows of one for sale or point me in the right direction id really appreciate it,thanks Greg
thanks cliff,i suppose your suggestion makes sense,ill check it out and see where i go from here,a lot to weigh up,thanks for the reply
Thanks Cliff ill keep the forum updated on any developements
How low is the compression, I've had some cars that just needed some gas treatment in the fuel tank that help clean the valves. I did an a2 last week that brought the compression up from 50 psi to 90 psi.
hi matty thanks for your reply,the guy who done the compression test said on bank 2 he was getting 6 bar where as on bank 1 he was getting 15 or 16 bar,the previous owner is very surprised to hear about this issue as he said it drove into the spot with no issues,the fuel pump was knackered when i got the car so i fitted a new one thinking it would run but now ive this problem
90 psi is still abysmally low, indicating gas loss at valves or rings.
Hi try pm to Audia4KEV he may well know of an engine.
That is low considering the others were at 200 psi, but that was after 2 days and only a few miles so a good run it would probably come up more. Any car that had been started up, moved a few meters then switched of before coming off cold start will be bad on compression for a bit.
thanks for all the help lads,i think ill concentrate now on getting my own engine sorted,as Cliff says a 2nd hand engine will still have a lot of work done so at least with my own one i can strip it and make it good again,itll be a project that i can work on over the next 7 or 8 months.thanks again
