Audi A4 B8.5 2.0 TDI quattro S tronic – gear hunting
Hi everyone,
I have a 2013 Audi A4 B8.5 Avant 2.0 TDI 177PS quattro with the 7-speed S tronic gearbox. I would like to ask for some opinions from people who have experience with this drivetrain.
The main thing I notice is that on A-road/main road driving, especially around 55–70 mph (90–110 km/h), the gearbox sometimes seems to hunt between 6th and 7th gear. It mostly happens with small throttle changes, slight inclines, or when I try to maintain a steady speed around 60–65 mph (roughly 100 km/h). It feels like the car is not fully sure whether it wants to stay in 7th for economy or drop back to 6th for more torque.
If I drive a bit more positively or at motorway speeds, the car feels great. Above about 70 mph (110 km/h) it is smooth, stable and the gearbox feels much more natural. The issue is mostly in that light-load cruising zone on main roads.
There are no warning lights and no gearbox fault messages. When I bought the car, the gearbox behaviour bothered me more, but a throttle/pedal reset seemed to improve it quite a lot. Later the S tronic oil service was also done, and that improved the overall feel as well. At the time I was told that this is more or less normal behaviour for this gearbox/drivetrain, so I accepted it.
The car also recently had a professional DPF cleaning/refitting job done. No DPF removal or performance remap as far as I know, just cleaning and related work. I am not sure if this is relevant, but I thought I should mention it in case DPF condition, regeneration behaviour, engine load, ECU adaptation/reset, or torque request could have any influence on how the gearbox decides between 6th and 7th. The gear hunting itself was not completely new after the DPF work, but I have started paying more attention to it recently.
I also sometimes notice a slight bump/jerk in stop-and-go traffic when accelerating with the queue and then lifting off the throttle to let the car slow down on engine braking. It is not a huge bang, but it can be felt as a drivetrain knock/torque reversal. It seems worse in situations where the car is crawling and the throttle is applied and released repeatedly.
My questions are:
  • Is this 6th/7th gear hunting around 55–70 mph (90–110 km/h) normal for the DL501/S tronic in a 2.0 TDI quattro?
  • Could this be mostly gearbox calibration/normal behaviour, or should I suspect adaptation, engine/gearbox mounts, drivetrain play, mechatronics, clutch adaptation, etc.?
  • Could DPF condition/regeneration/ECU adaptation have any effect on this kind of light-load gear hunting, or is that unlikely?
  • Would a proper S tronic adaptation/basic setting with VCDS or ODIS be worth doing, or is it better not to touch it if there are no faults?
  • For those with similar cars, how does your gearbox behave around 60–65 mph (around 100 km/h) in D mode on slight inclines or with small throttle changes?
  • Is there anything specific I should check before worrying about the gearbox itself?
I am not looking to immediately rebuild the gearbox or overreact, I just want to understand whether this is normal S tronic character or something that should be investigated further.
Any experience with A4/A5/Q5 B8/B8.5 2.0 TDI or 3.0 TDI quattro S tronic cars would be appreciated.
Thanks!
4 hours ago, jayformhu said:
Hi everyone,
My questions are:
Thanks!
Hi just try a gearbox reset that may well help with this, having the DPF cleaned won't affect the gearbox, normally after a gearbox service they do a reset so all the mechatronics can relearn its values.
Hi Steve,
Thank you for the reply!
By reseting the trans you mean I should go trough the "pedal" method? Which method should I use? Last time it didn't work for me or I just couldn't feel a difference in the trans' behavior. I also have a VCDS so I could use that as well but I'm not sure if it's a great idea for me to do so.
Also I guess I might be kind of a bad guy in this as well because in the past few months I've barely driven it on motorways or main roads and it was a combination of city drives and driving to neighboring cities that are 15mins from me. When the MTF/ATF oil changed was done they redone the adaptation and the car was a dream back then.
Thanks!
7 hours ago, jayformhu said:
Hi Steve,
Thanks!
Hi maybe it needs adapting again if you have VCDS there are plenty of how to do its on YouTube.
If you’ve had S Tronic gearbox service (every 38k miles), and you have VCDS, then I would do gearbox adaption calibration in basic settings. Few videos as mentioned. Try than and see if any improvement.
  • 4 weeks later...
Hi All,
Thank you for the answers. Since my post and your replies, I've started reaching out to transmission specialists, and it's been interesting, to say the least. None of them wanted to do an adaptation, and since I'm afraid to do it myself, it hasn't been done.
Only one mechanic was committed enough to take the car for a test drive. He mentioned that I might have a dual-mass flywheel issue, but at 30 km/h, he couldn't reproduce the symptoms. However, based on what I described, he suspects a clutch issue and suggested a full transmission rebuild.
I contacted another guy who seems like a great professional and has a very good reputation in Hungary. He told me that they don't really do diagnostics nowadays, but he suggested flashing the factory software onto both the ECU and TCU, just in case the car has a previous aftermarket tune. Other workshops never answered my emails, so I guess I will need to call them.
For now, I've put my car up for sale until September, and then we will see.
What are your thoughts on this? Should I go down the software update route or the transmission rebuild route? I definitely love this car, but if I sell it, I would like to buy one with fewer miles and a much better trim (for example, the B&O system, because I can't stand this 8-speaker setup).
I don't know specifically about your car, but the behaviour you describe is typical of modern automatic gearboxes. If the changes up and down are imperceptible, and can only be noticed on the dashboard display, I would not worry about it.
