RS7 Steering issues
Hi all, Ive got an rs7 c8 and recently a few days ago i noticed my steering feeling abnormally light. Even when changing into dynamic/RS mode it feels the same and doesnt stiffen up like it used to when I bought it a couple weeks back. Feels like Im losing control at higher speeds and just feels abnormal If im being honest. Wondering if anyone has experienced something like this before. I did go to my local audi and raised the concern they checked the shocks suspension alignment etc and said they couldnt see any issues. Any help would be greatly appreciated.
Hi, i havent had the tyres changed recently. I did have the alignment done over 5 weeks ago. Is an OBDeleven fine ? There are no faults showing on the dash
Hello Abeer,
Cutting into this thread, I begin to think that the wheel alignment alteration may well represent the point of change of this car’s handling, unless that chronology doesn’t stack up.
‘Tyres not changed ..’
What brand of tyres are on each axle?
Is the amount of tread even on both tyres on each axle?
What tyre pressures are you running, and have these been checked (when cold) against Audi’s recommended pressures?
Be aware, the increase in running pressures ( over cold set) will not be insignificant in these high ambient temperatures.
Regards,
6 minutes ago, Magnet said:
Hello Abeer,
Regards,
Hi Gareth, don’t you think if it was the alignment that caused this I would have noticed the steering change closer to when it was done or could this also be a possibility?
10 minutes ago, Magnet said:
Hello Abeer,
Regards,
Hello Gareth,
Appreciate your response. Do you not think if it was the alignment I would have noticed the difference closer to when it was done?
Regarding the tyre pressure they are all up to the guidelines from Audi and i checked these as soon as i felt the difference. The tread seems to be pretty consistent on all 4 also. It’s got the Ventus Stevo3 22s on.
11 minutes ago, Magnet said:
Many thanks Abeer,
Am I wrong in interpreting your description, that you have 22? inch wheels on the car?
Regards,
Yes that is correct. I think what is putting you off is the fact that I have Audi s3 8v on as the vehicle in my description bit? And yes they are 22inch wheels on my rs7
Thanks Abeer,
Before we get into more complex paths of modules etc. what else has been renewed on the car in recent times - however insignificant or unconnected it might seem?
Regards,
The change to steering alignment would have been felt immediately at the steering wheel. That the feel changed some weeks later means something else is causing the problem.
Power steering should always reduce as the speed rises in order to retain the "feel" or resistance to steering input. It sounds to me as if that reduction is not happening, so unless you can correlate some other alteration to the car to time of the light steering as Gareth suggests, I suspect a control fault that needs electronic diagnosis. I don't know if OBDeleven would do the job. VCDS is the usual recommendation for a fully functional code reader amongst those who know about these things.
As a side note can I ask why you changed the alignment? It is normally only done after a tyre change, new suspension parts, or a crash.
After I purchased the car, I noticed the cars alignment was out so went back to Audi to get it fixed. They confirmed it was slightly out of alignment and they had fixed it. Other than that no other work has been done to the car. Only got it about 5/6 weeks ago
Perhaps a daft question Abeer, but was the battery renewed shortly before you bought it?
I ask since if that new battery wasn’t coded to the car, then the alternator is likely to keep overcharging the new battery, eventually cooking it, but meanwhile resulting in it having an increased voltage over approx. 14.5V - at which point the EPS would become too assisted.
Regards,
