A7 rear door handle removal
Does anyone know how to remove just the outer part of the rear door handle on my new A7 I just bought. There is a slight scratch on it and I want to remove the handle to take it to be sprayed. Thanks in advance.
Welcome to the forum Stephen :)
youll find the members on here are a friendly bunch and will help you where they can :)
if it were me I'd take it to a body shop with the handle on the car so that they can blend it in to the car. If that makes sense.
steve
Any other ideas as I don't want to take the whole car up.
This might help
This is the outer bit I need to remove of the door handle itself. Would this come off separate?
Anyone with any knowledge???
In my experience  you would have to remove bolts etc inside door. Take door card off... but never done one on A7. Just check on door itself, if you open it. There maybe a bung to remove which exposes a screw on inner door shut.
