Oil sensor error shows up from time to time
Hello guys, I have a problem with my a4: the oil sensor error. I have already checked the wiring, everything seems ok down there. If I pull fuse number 15 and put it back, the cluster resets and it works fine (OK message) for a few times I turn on the ignition. Then the error shows up again. Does someone know where the problem could be?
  • 4 weeks later...
I have read a few times that VAG cars have reoccurring faults with these sensors in particular. For how much it costs it's a peace of mind thing for me.
Thank you very much guys, I will try to replace the sensor at the next oil change.
