Fuel filler
Hi all,
2010 A6 Le Man 2.0TDi
I have been having some issues with the emissions control warning light coming on. The garage suspect a dodgy sensor and have added some DPF cleaner to the fuel to help the situation?
When I checked the fuel filler earlier I could see straight down the fuel pipe. I am sure there used to be a flap across the neck of the filler. Should there be one?
As anyone else got a flap across the filler pipe? I wondered if this might be part of the problem?
Paul
2006 3.0tdi , no flap .
Ah ok, maybe I am just going mad. Thanks a lot.
Engine warning must be something else.
Welcome to the forum Paul :)
You'll find d the members on here are a friendly and helpful bunch :)
What kind of driving g are you doing? I ask as I'm wondering whether the dpf is able to do it's regeneration cycle properly.
Wgat garage are you using?
I too live in leicestershire and use AC motor services in Syston. Brilliant garage and very knowledgeable. Please note I have not links to them bar them fixing and servicing my a6.
Thanks for the reply.
I am mainly town but do a weekly longer drive. The dpf seems to regen as every so often the fan runs after turning the engine off. Also the revs seem a bit higher in idle every so often.
I take it to Tanvic in Loughborough as they have always looked after me.
They suspect the first sensor before the DPF?
Will investigate a bit more although it drives fine!
