Sign in to follow this
eddy52
lost car keys
Hy about 3 days ago i have lost my car keys. I have called a locksmith to make me a key with remote but he only managed to make a key with a chip so that i can start at least the engine and the 3 button remote does not open any of the doors of the car he tried several ways to fix the problem but no succes so far is there anybdy that can give me a guide what should i do? or in wich direction should i go? trying to get the cheapest solution so far...
Share this post
Link to post
Welcome to the forum, you'll find the members on here are a friendly and helpful bunch :)
Sorry to hear you've lost your keys. Without ringing around various auto locksmiths my only other advice would be to see Audi. But they will charge you alot for a new key.
Sorry I can't help more.
Steve
Share this post
Link to post
Hello Eduard,
If I'm reading this correctly, then you are 'back on the road', the car is useable, you can unlock the driver's door with the new key and I assume you can unlock the other doors once inside.
If so, as I see it, the remote doesn't work, but bearing in mind this is a 17 year old car, does it really matter much?  OK a bit inconvenient, but.....
As Steve says, the main dealer can probably re-code your remote (cost?). Worth ringing for a quote?
Share this post
Link to post
Loading...
