Mmi 2g high 2018 maps dvd
I have maps avaiable to downloand and burn for mmi2g high 2018 . Contact me
Due to the non offical source of the maps it would be unwise to post a link here unless admin agree :) @Trevor @Steve Q
Good job we aren't connected to Audi 😉 I'm ok with it Piotr but I think we should wait to see what Trevor says on the matter :)
I think anything that helps fellow members is a good thing :)
Steve
  • 2 months later...
Im New to audi ownership so please excuse if this is a silly question but will this work on a 2015 rs4? Thanks
No. In 2015 car you will have mmi3g
  • 10 months later...
Hi i have just brought a 2008 a5 i believe it has mmi2g high does this update also update the mmi or is it just map's? thanks.
Maps are maps , software is seperate
Are you sure you have mmi2g high ?
I think a5 had 3g
Have you got a dvd drive with 2 sd card slots ?
No I don't have sd slots i have ami in glovebox I'm pretty sure its mmi 2g from what I've seen.Ive since found that i already have the latest version of maps and mmi.I was struggling to stream to the after market Bluetooth kit a previous owner had installed but I've finally figured it out. Thanks for replying
