Sign in to follow this
dakes55
A8 D2 Fuse box location
can anyone tell me where the fuse box is located on a 2002 A8 2.8 Quattro, most of the other Audis ive owned have been at the right side of the dashboard end, its a right hand drive car
Thanks
Share this post
Link to post
Hi John I believe the fusebox is under the dash in the passenger side footwell. There will be a plastic cover you need to remove.
Steve
Share this post
Link to post
HI, thanks for that Steve, all that I can find there are relays, and a long flat black plastic tube that looks like it feeds the heating to the rear of the car, I cant see any plastic cover anywhere or the fuse box in this location ?
John
Share this post
Link to post
42 minutes ago, niedzial1983 said:
Usualy on audies there are on both ends of the dash as you open the door
I thought that too but I guess in light of John looking it must be on the left side?
John
Hmm, well all I can think is that it's on the other side of the dash (on the end and on the opposite side to where you've looked)
Steve
Share this post
Link to post
yes it a weird one and i cant find any info about it on the net, so i think i will have to call Audi and ask them, nothing on ends of dashboard by the way
Share this post
Link to post
Did you try to remove plastic trim , side panels of the dash as you open the doors?
Share this post
Link to post
At last I found the fuse box, for future reference its located in the driver side pillar, but not under the carpet.
Share this post
Link to post
Glad you found it :) was it the fuse at fault?
Steve
Share this post
Link to post
I have a 2000 Audi A8 and can’t find the fuses. I found one spot in the trunk but it only had 4 fuses. And on the sides of my dash are air vents not a solid piece of plastic. Does anyone know where they could be
Share this post
Link to post
İt located Side column in front of right front door you have remove plastic cover to reach
Share this post
Link to post
Share this post
Link to post
Loading...
