JAudi Posted May 7, 2018 Share Posted May 7, 2018 Hi All, Just wondering if anyone on here has spoke with Audi UK regarding the recent electric coolant pump recall or had the part replaced by Audi? Cheers Jim Quote Link to comment Share on other sites More sharing options...
Steve Q Posted May 8, 2018 Share Posted May 8, 2018 Hi Jim, I believe the c7 is being recalled as the pump has a risk of fire if it becomes blocked or has a short circuit. Here's the link to the NHTSA: https://www.nhtsa.gov/recalls?nhtsaId=18V229#recalls370 From the sources I've read the necessary replacement parts aren't available until June so the letter you've received is to inform you. You'll get another nletter to let you know when the part is available and for you to book your car in for the recall. Cheers Steve 1 Quote Link to comment Share on other sites More sharing options...
Envy Posted May 8, 2018 Share Posted May 8, 2018 4 hours ago, Steve Q said: Hi Jim, I believe the c7 is being recalled as the pump has a risk of fire if it becomes blocked or has a short circuit. Here's the link to the NHTSA: https://www.nhtsa.gov/recalls?nhtsaId=18V229#recalls370 From the sources I've read the necessary replacement parts aren't available until June so the letter you've received is to inform you. You'll get another nletter to let you know when the part is available and for you to book your car in for the recall. Cheers Steve https://www.gov.uk/check-vehicle-recall 1 1 Quote Link to comment Share on other sites More sharing options...
