Stabilisation Control (ESC) Fault - Engine will not start
Hi all,
I have been having an issue with my A4 1.8 TFSI (62 Plate) over the past couple of weeks.  Its been driving fine no concerns at all when one morning it wouldn't start and a display message comes up saying "Stabilisation Control (ESC) Fault.  The engine is turning over but won't start.  I have scouted online and there seems to be a mixed response to this.  I have had a diagnostic ran and been given a list of fault codes but nobody can seem to get information on them.
I have attached some pictures and a video
Any help or advice would be massively appreciated.
Conor
Looks like battery failing... low voltage will show all kind of fault codes
Thanks for the reply. I've looked into the battery. I've taken it out and had it tested. Voltage and capacity came back ok. Its not an issue with the battery
  • 1 year later...
Hi Conor,
I’m having the same issue with my A4. Did you find a solution?
thanks!
Blair
  • 11 months later...
Has any of you got the solution to the above problem? Been having the same problem for weeks now but wen the car was left in the son for a long time it started and was fine for two days but now its back there again
  • 8 months later...
Did you find a solution? My a5 is doing the same thing.
Edited by Dmdm1r
Changed the battery but unfortunately still having the same intermittent issue. Doesn't seem to be any rhyme or reason as to why it starts or not.
My next port of call would be a diagnostic check
  • 2 years later...
Hi everyone
I have same issue on A5
Did you found solutions or the origin of the problem?
Thanks a lot
