A3 drivers door
HELP
I have an Audi A3 sportsback 57 plate and can’t get the drivers door to open from either the inside or outside. Even tried using the key on the drivers door rather than the central locking and still no luck!
Ann.
I assume you mean the door won't unlock rather than being physically jammed by crash damage or the like.
If the other doors work then the chances are that the driver's door lock has failed. If none of the other doors operate then the central locking system has failed. Either way there is little you can do yourself unless you are handy with tools.
  • 9 months later...
I also agree with you, the problem must be resolved and giving suggestions about hiring emergency locksmith firms is not suitable at all.
Hello Wesley,
I’m rather lost by your comment that recommending getting assistance from a locksmith - at the time- is/was not suitable at all.
Strange.
