Jerbear Posted May 11 Posted May 11 Hi all. Quick question, I have 18" on my Allroad yet the Wheelshop recommended a 19" spacesaver ?
Magnet Posted May 11 Posted May 11 Space savers are usually of a lower profile, so just check the rolling diameter of your 18 inch wheel and tyre, and compare it with the figure you will be given for the same dimension of a 19 inch spacesaver. You will also need to check if it will fit in its compartment. Let us know how you get on Jeremy. Kind regards, Gareth.
Jerbear Posted May 11 Posted May 11 Thanks Gareth, will do. Always had a spare of some sort, doesn't feel right without .
