2010 Audi A4 DPF issues
I have a 2010 a4 avant 2.0tdi.
engine management light came on due to DPF pressure sensor.. has now been changed but light is still on. Any advice on this?
car was sent off for a new clutch and they changed a centre sleeve on the exhaust and now car has flashing coil light down to EGT sensor 4.. and now particulate filter light has come on also...
haven’t changed the sensor as of yet due to not knowing location of sensor.. a few people have mentioned it is the second sensor after DPF is this correct? And also would changing this resolve the issues as they are the only 2 codes coming up when plugged in?
thanks.
Hi Mike, as you seem mechanically minded, I think your best course of action would be to dismantle the dpf and examine it's condition. Clean it a f change the second sensor or both and then see if that sorts it.
  • 2 months later...
I assume you have scanned it for codes, if so put the scan on here so that we can help.
