Rear Coil spring Replacement
DIYDaly
  • 1 month later...
Hi hope this is ok to ask here...
I have a S-line Quattro estate with the red rear dampers (sports suspension?) I have just ordered some new dampers as the old ones are leaking oil.
The ones that have turned up are SACHS 313 367 which going by the information are for standard suspension? should be 313 368 for sports?
Assuming the car still has Sports springs (replaced by previous owner due to cracked springs) is it ok to use a standard damper with sports springs? or will this cause an issue?
