Help Required Window Regulator.
Hello.
Is there anyone that lives in our around the Aberdeen area that can assist?
I have an A4 B7 S Line Saloon and the front drivers side electric window will not operate. When the switch for the window is pressed all I hear is strange noises and no window movement.
Due to serious illness I cannot bend over or crouch down for any length of time. Is there anyone in the local area that could strip the door down, remove old window regulator and replace with a new one then reassemble the door.
If there is, can you message myself a cost to carry out the work. The car is located outside Bucksburn head toward Haudagain Roundabout. I’m not too sure when the job can be done as I am frequently admitted in to ARI.
I look forward to any replies.
Regards,
Stuart.
Yes Steve. Sometimes you just never know.
Hello Steve,
I have posted on the group page but had no response back. Worst part of living in Aberdeen, I’m at the wrong end of the country.
Yes, I think I will.
