Engine Management Light
Last night, after hitting a deer, the yellow light of an engine  came on the dash. Manual says that it is to show a fault in the emissions system.
Question - does the Audi A3 8Y have an Engine Management Light -  that glows red if urgent attention is required. I can't find any mention of one in the manual.
There should be a red one too. Usually any red light indicates you should stop. Regardless though you need to be getting it to a garage as clearly something has broken and the car isn't running right efven if it may appear it is.
  • 3 months later...
It does..had the orange one show up then vanish when the alternator was playing up. This happened a few times. Then i got a red one which told me to stop ASAP (which i didnt) and then it eventually died. Alternator had died and so did the battery so had to go in to get a new alternator fitted.
Moral of the story- stop if it tells you to stop!
