Retrofit - heated & ventilated seats
Has anyone ever done this to a car that has neither as standard?
im assuming that apart from the seats, new seat to climate control unit wiring looms  and a new climate control unit are needed.
But, would I also need to pick up a new high ampage supply for the heating and then get the climate unit coded to the car?
I’m also assuming that the heating and ventilation control units are in the seats, so no extra bits?
Im a retired engineer and I’ve done similar jobs before, so not daunted by anything apart from the coding bit.
cheers all
Dave
Yep I believe it would need to be coded. You've listed tbe bits you need 👍 not sure if it would be different but make sure the airbag connectors are the same as yours with any seats you buy. The heater elements are in the seats I believe.
