Audi A6/C7 2.0 TDI Ultra whistling/whirling when accelerating
Hello dear member,
I own Audi A6 (C7) 2.0 TDI Ultra S-Tronic from 2016. I hear whistling/whirling sound when accelerating slowly or harder from 60 mph/70 mph at 4th, 5th, 6th or 7th gear even if I drive slower and want to accelerate this sound is hearable from front of the car. The sound comes from left/centre/front side of the car and is noticeable behind the dashboard. When I switch gear on neutral when driving is quiet also if car is stationary on parking gear to do revving nothing is happening as well. The sounds appearing only when accelerating not when revving. I also attached two files as a proof. Thank you
Turbo whistle? Couldn't really hear much from the files. But any whistle when accelerating is usually the turbo. I can hear something, occasionally, but best to give timestamps of when it occurs.
Hello,
The best way to hear that sound when accelerating is to use earphones but also without it whirling is noticeable in the background. I was driving on motorway with mixed surface where was some traffic. Pop up the volume as much as you can then you will find out what I mean. You right I highlight bits when I hear swirling sound.
The first soundtrack:
0:06 - 0:13
1:51 - 1:56
Swirling sound is hearable in first soundtrack nearly all the time in the background but is quite because I wanted to keep the same speed to record that sound at 66mph.
The second soundtrack:
0:13 - 0:30
0:55 - 1:12
1:12 - 1:22
1:36 - 1:44
2:04 - 2:20
That isn't the usual turbo howl, so Steve may well be right it's a leaking pipe.
No smoke and no loss of power mean if it is the turbo, it's not blown.
Let us know what your local garage says. You're in Coatbridge, so you could try A for Audi in Glasgow for a diagnostic.
I was thinking it could be something related to inflow of air. Probably not enough air going in or out and this make whirrling sound hearble on the soundtrack during acceleration. Leaking pipe from turbo it can be solution because don't have smoke from exhaust, loss of power or turbo howl as well. When driving slower turbo seems to work normally also when drive at high speed everything looks good except this whirrling sound from the engine. I asked in Audi for diagnostic but they couldn't precise how long doesn't it take so I didn't wanted pay hundreds of pounds not knowing how many hours they spend on my car😉
  • 7 months later...
Hello! How did you solve?
Hello, unfortunately I didn't solved it yet. I guess it could be seal from turbo charger or leaking pipe. I don't want to think about faulty turbo unit because it could be so expensive to fix.
I got one of these from my SnapOn guy a few weeks ago to troubleshoot these type of problems:
https://shop.snapon.com/product/Portable-Diagnostic-Smoke-Machines/Smart-Smoke-EVAP-Machine/EELD500
If you can find somebody local to you that can run a smoke test the time paid to diagnose will save you heart ache trying to find yourself
  • 1 year later...
Hello NeroRapid, did you solved your problem? I guess I got same issue. Thanks
Most likely a failing turbo or turbo pipes? Check the pipes first.
  • 1 year later...
very sorry for bumping an old thread.
by any chance maybe anyone has sorted this thing? I have exact the same problem and I do find it on different forums, but nowhere an answer what could it be. A4 B8.5 Ultra 2.0 TDI;
pulsation is me slightly lifting off the foot from the pedal.
Already have looked through the bearings, tyres, exhaust, timing belt was replaced recently due to mileage, but it was before that.
What have you tried so far? Assuming you've read this thread have you looked to see if any of the suggestions help?
I have taken my car to a local garage to check on suspension related issues: wheel bearings were tested on lifted car, one was changed, but without any results. They have also inspected exhaust pipe for any leaks/holes or connections, tyres were swaped front to rear. I see member Gojko, which also had this problem, but isn't clear what was solution for him in case he solved it. The sound on the OP clips and on my video looks very similar to me, so I'm wondering. Turbo pipe checking looks pretty complicated to do by myself since my car has water cooler intercooler and the air pipes are going behind the engine if I understand it correctly. The symptoms described in the first post looks the same. Speed dependent sound, no matter what gear is on, clutch removes the sound, very slow or minimal acceleration.
Edited by TDI_inside
  • 4 weeks later...
On 7/25/2025 at 12:18 AM, Steve Q said:
I'd have to agree with you. Please keep us posted on how you get on
So a month has passed, holiday time of the year - long waiting time, I have visited gearbox specialist - two of them and they do confirmed, that it is the gearbox fault and the sound is from there. Could be bearings which can be replaced, could be something else which is too expensive to repair - so gearbox swap looks like natural decision in this case. And hope it will not repeat.
