Hi folks. Anyone any ideas my April A4 cabriolet interior lights have all stopped working. I think power is getting to switches as the switches over the rearview mirror light up when the lights are on but nothing happens when I press the buttons. The fuses seem ok. Any pointers appreciated
Hi only way to find out is by having a diagnostic scan which should throw up the fault.
there is a one amp fuse that light the dash ect in  my a8  yours may be the same (its any easy thing to check first)
Have you got wet carpets?
I believe a sign of a wet ccm can failed interior lights.
Thanks Michael, what was the cause?
  • 1 year later...
Hi Michael I have the same issue how did you fix ?
Hello Justin,
As you can see, Michael never shared the solution. You might have more luck if you PM him.
Would you please be kind enough to post the outcome if you get a response.
