Electrical fault drivers door 2014 A4 B8
Yellow warning light come on. Auto lock no longer works. Use fob and all doors apart from drivers door locks. Battery in fob new. Driver’s mirror also doesn’t fold in. Any help appreciated
Hello David,
Worth checking within the flexible harness section between the door and the body A post. It’s not uncommon for wires to fracture within this section due to regular opening and closing of the door - particular in cold weather when the harness becomes  more brittle.
Cheers will take a look
