Lost power steering
Sudden powersteering loss
No fault codes or warning lights
Solved by Np.sanderson
Hi check the connector to the power steering motor as they are prone to corrosion on the pins, then check the wiring from the plug up as far as possible for broken wires, even if you have to remove the loom wrapping its easily replaced, genuine loom tape on eBay is pretty cheap.
Cheers Steve I will try this and let you know
  • 5 weeks later...
  • Solution
It was a battery issue connection was lost to ecu.my scanner is only a cheap one and didn't pick up the fault.
